Given that the resultant mmf wave in the air gap of the three phase two pole induction motor is $$F(\theta , t) = \frac{3}{2}NI_m \cos(\omega t - \theta) \tag{1}$$ what's the value of the induced voltage in the phase coils? According to the Faraday's law of induction, we have $$\text{emf} = -N\frac{d\Phi}{dt}\tag{2}$$so we should calculate the flux linkage of the each phase coils and differentiate the result to obtain the induced voltage but I don't know how to find flux linkage. I've check various sources including Electric Machinery and Principles of Electric Machines and Power Electronics but they didn't help me to understand the solution. I'm mostly interested in the mathematical answer to this question rather than qualitative answer.
Edit: My problem main is as follows. According to the first equation, flux density should be of the form $$\vec{B} = B_{max}\cos(\omega t - \theta)\hat{r}$$so the flux linkage is $$\lambda = N\int_{-\pi/2}^{\pi/2}\int_{0}^{l}B_{max}\cos(\omega t - \theta)\hat{r}.rdzd\theta \hat{r} = NlrB_{max}\times2\cos(\omega t)$$the induced voltage should be $$\text{emf} = -\frac{d\lambda}{dt} = 2Nlr\omega B_{max}\sin(\omega t)$$ But it's given that $$e_a = k_w N_{ph} \frac{d\Phi_p}{dt} \cos(\omega_e t) - \omega_e k_w N_{ph} \Phi_p \sin(\omega_e t)$$ Apart from the scaling factors, why there should be $$\frac{d\Phi_p}{dt} \cos(\omega_e t)$$ term in the induced voltage? Also what changes has to made if the rotor also rotates? How the "slip" comes to the equations, in that case?
