Linear amplifiers such as class A, B, and AB can deliver current to the load. Then should it be regarded as a current source?
However, a current source should have a high output impedance while a voltage source should have a low output impedance. Now consider the following class B amplifier. It is in the emitter follower configuration. The impedance looking into the emitter is low and hence the output impedance should be low. So in this case, should this linear amplifier be regarded as a voltage source instead of a current source?
Source: https://www.electronics-tutorials.ws/amplifier/class-ab-amplifier.html
Consider another class B amplifier configuration in the following diagram. Now it is in a common source configuration. The impedance looking into the course is high and the output impedance is also high. So in this case, should the power amplifier be considered as a current source?
So as a whole, can we say that a linear amplifier can either be a current voltage or a voltage source depending on its configuration?
