I am making a 5 level inverter using an Arduino Mega. I am using an IRFZ44N MOSFET for switching and also an MCT2E as a MOSFET driver.
The problem I am facing is that I am a getting a lower output voltage than expected: the actual output should be 24V, but I am getting 12 - 13V as output.
Can anyone help me out with this problem?
This is the schematic:
This is the code I am using:
float f = 50;
float t = (1 / f) * 1000000;
float a1 = 10;
float a2 = 40;
float a1p1 = (a1 * t) / 360;
float a1p2 = (a2 * t) / 360;
float d = 5;
int pin1 = 1;
int pin2 = 2;
int pin3 = 3;
int pin4 = 4;
int pin5 = 5;
int pin6 = 6;
int pin7 = 7;
int pin8 = 8;
void setup() {
pinMode(pin1, OUTPUT);
pinMode(pin2, OUTPUT);
pinMode(pin3, OUTPUT);
pinMode(pin4, OUTPUT);
pinMode(pin5, OUTPUT);
pinMode(pin6, OUTPUT);
pinMode(pin7, OUTPUT);
pinMode(pin8, OUTPUT);
void loop() {
digitalWrite(pin1, HIGH);
digitalWrite(pin2, HIGH);
digitalWrite(pin5, HIGH);
digitalWrite(pin6, HIGH);
delayMicroseconds(a1p1 - d);
digitalWrite(pin2, LOW);
delayMicroseconds(d);
digitalWrite(pin4, HIGH);
delayMicroseconds(a1p2 - a1p1 - d);
digitalWrite(pin6, LOW);
digitalWrite(pin8, HIGH);
delayMicroseconds(t / 2 - (2 * a1p2) - d);
digitalWrite(pin5, LOW);
digitalWrite(pin7, HIGH);
digitalWrite(pin1, LOW);
digitalWrite(pin3, HIGH);
delayMicroseconds((2 * a1p1) - d);
digitalWrite(pin4, LOW);
digitalWrite(pin8, LOW);
digitalWrite(pin7, LOW);
digitalWrite(pin3, LOW);
delayMicroseconds(a1p1);
