I seemed to have pressed some hotkey activating a white outline around same layer objects during interactive routing. See image below. It seems to slow down FPS quite a bit, so I'd like to disable it. Can someone tell me (1) What the white outline means / what it's for (2) How to disable it?
    \$\begingroup\$ At a guess, that's probably showing the clearances. \$\endgroup\$
    – Hearth
    Dec 29, 2020 at 21:25
  • \$\begingroup\$ You can "shelve" your polygons, so it won't have to calculate how to rearrange them as you route the track. \$\endgroup\$
    – The Photon
    Dec 29, 2020 at 21:34
I think @Hearth is correct.
Try Preferences->Interactive Routing->Interactive Routing Options and de-select "Display Clearance Boundaries".
  • \$\begingroup\$ yes, thank you! I enabled it by pressing ctrl+w instead of shift+w to select user track width. \$\endgroup\$
    – Xaser
    Dec 29, 2020 at 23:01
    \$\begingroup\$ Excellent. When I was learning I used the View->Desktop Layouts->Default a lot. \$\endgroup\$ Dec 29, 2020 at 23:58
