I have a problem regarding footprint clearance or something similar while using Altium 18.1.11. The problem occurred as I designed a Pad with via on it but when I imported it to the PCB doc, the part has a huge room that is larger than the footprint itself and Altium did not allow me to place them properly. I have tried looking at the Footprint by using "Find Similar Object" but only the Pad and the vias are in the Footprint as I thought there might be another object in the footprint that caused this issue. Thank you in advance!
\$\begingroup\$ turn on the other layers, there's most likely some artifact on a different layer that is causing this. \$\endgroup\$ – Aaron Dec 31 '20 at 18:38
\$\begingroup\$ You probably can't place it becuase those vias are assigned different nets than your circuit (or no net at all). Altium won't let you create short-circuits between nets. The solution may be to click on each via in your pad, assign the right net to it. ..... Maybe ;) \$\endgroup\$ – Kyle B Dec 31 '20 at 19:20
Add a comment
