Currently I'm planning on doing a PCB with DDR3 memory and an Artix7 FPGA. During my research a few questions accumulated.
When looking at the reference manual of the Arty7 board, I see that I have to configure DDR3 output drive strength and On-die termination to RZQ/6. Using a 240 Ohm reference resistor, RZQ/6 equals 40 Ohms. On the other hand, the manual states, that all traces are 50 Ohm traces (100 Ohm differential) and that the FPGA's termination should be configured to 50 Ohms. Another thing is, that the Address/Control signals are all terminated with 40 Ohms according to the schematic.
The schematic of the arty7 board can be found here. The DDR3 memory and its 40 Ohm termination resistors are shown on page 9.
To me, it would be more logical to use 40 Ohms everywhere. Why is this impedance mix used? I know, that for higher speed DDR3 applications 40 Ohm systems are typically used. However, to me, it seems completely unlogical to go with 50 Ohm traces, when you can't even configure the ODT to 50 Ohms: RZQ/6 = 40 Ohms, RZQ/4 = 60 Ohms, assuming 240 Ohm RZQ. (I've never seen another value besides 240 Ohms).
  1. Can someone clarify this impedance stuff?
Technically, the DDR3 device using 40 Ohm output impedance on a 50 Ohm trace and load should't affect signal integrity, but affects the signal amplitude.
  1. Don't you get overshoot when driving a 50 Ohm net with a 40 Ohm driver?
  2. How is signal integrity guaranteed, when using a 50 Ohm line impedance in combination with 40 Ohm termination resistors?
For my design I initially intended to use 40 Ohm traces, 40 Ohm termination resistors on address lines and an ODT setting of RZQ/6. for a 1000Mb/s transfer speed DDR3 device. Unfortunately, this is a hobby project and I don't have access to SI simulation tools to verify this using the IBIS models.
    \$\begingroup\$ One disadvantage of 40 ohm traces is that they will be wider than 50 ohm traces, for a given stackup. When you have a wide memory bus to route, this can really add up. As for why 50, I think it's just board houses wanting to go with what they're familiar with. \$\endgroup\$
    – mng
    Commented Jan 2, 2021 at 1:07
  • \$\begingroup\$ Yes. I know, that 50 Ohm are more "standard" and thinner than 40 Ohm traces. But I'm still confused why the Arty 7 board uses 50 Ohm lines and a 40 Ohm termination. The second problem is with the bidirectional lines using ODT: The FPGA is configured for 50 Ohm and the DDR Memory for 40 Ohm using 50 Ohm traces. This is actually kind of confusing to me. \$\endgroup\$
    – GNA
    Commented Jan 3, 2021 at 18:39
  • \$\begingroup\$ As you said, you get overshoot - a small amount - with a 40 ohm driver and a 50 ohm transmission line. This is by design, as that small amount of overshoot comes with slightly faster rise and fall times, which is desirable, usually. \$\endgroup\$
    – SteveSh
    Commented Jan 3, 2021 at 20:36
  • \$\begingroup\$ How about the other direction? From FPGA to RAM on data lines. With a 50 Ohm line and a 40 Ohm ODT you will get the opposite effect. \$\endgroup\$
    – GNA
    Commented Jan 3, 2021 at 20:40
  • \$\begingroup\$ When you're going from the FPGA to the RAM, the RAM driver output and its associated 40 ohm resistor should be disconnected from the line. \$\endgroup\$
    – SteveSh
    Commented Jan 3, 2021 at 21:17
Intel spec
Table 4-8: General Layout Guidelines DDR 2,3,4
Guidelines
Parameter
• All signal planes must be 50-60-ohm, single-ended, ±10% • All signal planes must be 100-ohm, differential ±10% • All unused via pads must be removed, because they cause unwanted capacitance
Impedance
DDR2, DDR3, and DDR4 SDRAM Board Design Guidelines Altera Corporation
Lower impedance demands excessive wide tracks or too thin PCB is only 2 layers for height to width ratio of dielectric H/W.
3.6V logic is a 25 ohm driver +/-25% typ so 40 Ohm was sometimes used to reduce risetime slightly. PCB tolerances for Zo are typ 10% if certified with Electrical TDR tests on a test coupon then D Codes are scaled to suit the batch to guarantee tolerances otherwise they can be greater.
Here you can see the effects of a few combinations of 50 ohm traces but different source and loads. I added some lead inductance of 1nH + 1pF for ~ 1 to 1.5 mm over a ground plane.
