One solution, which more experienced people would hesitate to suggest because it perpetrates the dead-end practice of using delays, but it's close to what you already have, is to modify slightly the single thread you have, to update all three phases.
Use a phase increment of 120+delta (degrees)
DELTA = 10 # degrees
SOME_TIME = 1.67 ms - processing_time # choose to get 50 Hz
phase_index = 0
phase = 0
while forever:
phase_index = modulo(phase_index+1, 3)
phase = modulo(phase + 120 + DELTA, 360)
write sin(phase), phase_index
delay SOME_TIME
There's no need to implement the pseudocode exactly like this. You could simply index through a table of sine values. Or phase and sine(phase) could be rolled into one by implementing a complex vector, and rotating it by multiplication each pass through the loop.
Choose DELTA and SOME_TIME to rotate through all three phases in one period of the underlying waveform. Here, the three phases get written with 30 degrees being advanced, so we've got 12 samples per cycle of each output.
Now without much change, we can have a very much better solution
setup_timer_interrupt(1.67 ms, output_a_sample)
SOME_TIME = 1.6 ms - processing_time # choose to get 50 Hz
phase_index = 0
phase = 0
function volatile output_a_sample():
Now you can have a main() function running completely independently of the timer interrupt.
