I am designing a PCB footprint for this part: https://www.meanwell.com/productPdf.aspx?i=685
On page 4, the pins diameters are indicated as: diameter:1ψ and diameter:2ψ
Also, on the quotes, they are using 2-1ψ and 2-2ψ
I searched the web for answers but could not find anything useful..
What is ψ? Why is it used instead of millimeters? How can I convert this to metric? How large are the diameters of these pins?
  • 5
    \$\begingroup\$ I guess they simply mistook the '⌀' for a 'ψ' to denote 'diameter'. The unit should be millimeter still. "2-1" should be read as 2 times 1mm (as there are two pins). \$\endgroup\$
    – asdfex
    Commented Jan 2, 2021 at 11:18
  • \$\begingroup\$ The sign appeares in many meanwell documents... google.com/search?q=meanwell+%CF%88 \$\endgroup\$ Commented Jan 2, 2021 at 14:31
  • \$\begingroup\$ They probably intended to use an upper case phi. Which is still wrong, a diameter symbol has the slash at an angle. \$\endgroup\$
    – Mattman944
    Commented Jan 2, 2021 at 15:21
That is not a letter "psi". It is diameter sign. 4 holes with diameter 3.5 millimeter.
    \$\begingroup\$ Nope, that is an actual Unicode character ψ in the document. \$\endgroup\$
    – asdfex
    Commented Jan 2, 2021 at 13:31
  • \$\begingroup\$ Yes, you right. So may be file creator mistake. \$\endgroup\$
    – user263983
    Commented Jan 2, 2021 at 13:34
  • \$\begingroup\$ a quick google search shows many meanwell PDFs with the sign making it not likely a mistake... google.com/search?q=meanwell+%CF%88 \$\endgroup\$ Commented Jan 2, 2021 at 14:29
  • \$\begingroup\$ How did you reach the 3.5mm number? Also considering the 4 pins have two different sizes... \$\endgroup\$ Commented Jan 2, 2021 at 14:34
  • \$\begingroup\$ 3.50mm 4 holes. Page 4 in the link, OP provided. I did not reach but read that. Why Meanwell using that sign is only Meanwtell documents writer knows. I do not insist, only guess. \$\endgroup\$
    – user263983
    Commented Jan 2, 2021 at 16:04
The same character shows up in their datasheets to mean phase.
If I copy the character out of the datasheet and paste it into a blank PDF, there is a warning of font substitution and this Arial character is pasted:
Maybe a muck-up similar to the frequently-seen Ω/W substitution in pdf datasheets.
The original uses a number of traditional/simplified Chinese fonts, apparently from the Mac world.
So the meaning should not be uncertain, despite the similarity to the wave equation.
