As you've read on the title, my problem is about an oblique incidence problem over a stratified electrical medium.
I've made a quick sketch with the incidence on the first layer. Let's suppose that I have a TE incidence, even if it is not important to my question.
I tried to solve the problem using the transfer matrices. For the first interface between layer 1 and 2, for example, I have:
$$ \left[\begin{matrix} E_1^+ \\ E_1^- \end{matrix}\right] = \underbrace{\frac{1}{t_{12}}\left[ \begin{matrix} 1 & r_{12} \\ r_{12} & 1 \end{matrix} \right]}_{M_{12}} \left[\begin{matrix} E_2^+ \\ E_2^- \end{matrix}\right] $$
with
$$r_{12}, t_{12} \in \mathbb{C} \quad \mathrm{and} \quad M_{12}\in \mathbb{C}^{2 \times 2}$$
The coefficients \$t_{12} \$ and \$r_{12}\$ are computed using the Fresnel equations.
Obviously before I can add a second interface matrix, I should add a propagation matrix:
$$ P_2 = \left[ \begin{matrix} e^{-j \beta_2 \ell_2} & 0 \\ 0 & e^{j \beta_2 \ell_2} \end{matrix} \right] $$
Where \$\beta_2 \$is the propagation constant in layer 2 in the axis orthogonal to the interfaces and \$l_2\$ is the thickness of layer 2. For N layers I have:
$$ \left[\begin{matrix} E_1^+ \\ E_1^- \end{matrix}\right] = \underbrace{M_{12} P_2 M_{23} P_3 \cdots M_{N-1, N}}_{M_\mathrm{tot}} \left[\begin{matrix} E_N^+ \\ E_N^- \end{matrix}\right] $$
I numerically computed:
$$ M_\mathrm{tot} = \left[ \begin{matrix} m_{11} & m_{12} \\ m_{21} & m_{22} \end{matrix} \right] = \left[ \begin{matrix} 1/t & r/t \\ r/t & 1/r \end{matrix} \right] \qquad \mathrm{and \ I \ plotted \ how} \ |r|^2= \left|\frac{m_{21}}{m_{11}}\right|^2 \ \mathrm{ varies \ with} \ \theta $$
Where \$|r|^2\$ is the reflection coefficient.
This gave me nonsense results: I have for some angles a reflection coefficient greater than one.
I think that the main problem is that the propagation matrices are not unitary.
If I compute the determinant for \$M_{12}\$, I get:
$$ \det(M_{12}) = \frac{1}{t_{12}^2}(1-r_{12}^2), $$
Using the definition \$t = 1+r\$, then: $$ \det(M_{12}) = \frac{1-r_{12}^2}{(1+r_{12})^2} = \frac{1-r_{12}}{1+r_{12}} = \frac{1-(t_{12}-1)}{t_{12}} = \frac{2}{t_{12}}-1. $$
This means that the determinant of these matrices can be also greater than one with certain angles.
I am doing something wrong, but I can't see it.
I've also thought to use the scattering coefficient S21 instead of transmissivity t, but the transfer matrix requires the use of Fresnel coefficients.
  • \$\begingroup\$ This is probably better suited to physics.se \$\endgroup\$ – user16324 Jan 2 at 12:04
  • \$\begingroup\$ Brian why? I am sure we can answer it here. \$\endgroup\$ – The Force Awakens Jan 2 at 12:13
  • \$\begingroup\$ Thank you, I will ask to physics too, I've just post here before because I'm an engineer too. However I'm sure some electrical/electronics/telecommunication engineers here are skilled on this topic. \$\endgroup\$ – gab____ Jan 2 at 12:29
  • \$\begingroup\$ People here are skilled in all sorts of things that aren't valid questions. \$\endgroup\$ – Finbarr Jan 2 at 14:37
  • \$\begingroup\$ @TheForceAwakens then go ahead! \$\endgroup\$ – user16324 Jan 2 at 21:18
