I have encountered several terminals, sockets, cables, and similar components which are rated in either DC or AC voltage, but not both. I sometimes want to use an AC rated part with DC or vice versa. Is there a way to identify when this is obviously unsafe?
For example, I know not to use something rated for 12VDC with 125VAC.
To give a specific case, I want to know if I can use this https://www.grote.com/electrical-connections/trailer-connectors/heavy-duty-7-way-connectors/82-2145/ 40a @ 28 VDC rated socket with a 10a @ 125 VAC load. Thank you.
... extend that to 28 VDC \$\endgroup\$
