enter image description hereA while ago i have opened an electronic balance charger for a reason to try understanding how the circuit works so I've drawn the entire circuit for that purpose but i no longer have the drawing, but i remember the place of high capacitor voltage in that circuit so i only drew the part where the capacitor is present, to illustrate
and which i would to know is the capacitor role in that circuit, According to what I understood is that capacitor role is Cut down an amount of voltage by acting as closed circuit During capacitor charging,
so my qeustion is that correct? and if is correct i would to know about the others lines connected with capacitor positive line does current will flow to them during capacitor charging a cause of high voltage? because i know in low voltage no current will flow to any line with resistance until capacitor fully charged,
notice : the power source is 220 V and thank you all for any help.
  • \$\begingroup\$ I presume the C was low ESR type to improve step current response \$\endgroup\$ Jan 3, 2021 at 22:39
  • \$\begingroup\$ i dont think so \$\endgroup\$
    – user270262
    Jan 3, 2021 at 22:43
  • \$\begingroup\$ If, as you say, the power supply is 220V, then the capacitor is under rated. A 220V nominal supply is permitted (in US at least) to vary by 10%. So, consider 242V. But more importantly, that is rms value. You need to find peak, which is 1.414 times greater. 242*1.414= 342.2V . Capacitor needs to be rated above that. \$\endgroup\$ Jan 3, 2021 at 22:44
  • \$\begingroup\$ The step response can unbalance cells with mismatched ESR’s during the step, so I think so, the voltage limiters in each cell then must balance the cell voltage after the step. \$\endgroup\$ Jan 3, 2021 at 22:44
  • \$\begingroup\$ "i know in low voltage no current will flow to any line with resistance until capacitor fully charged," That is incorrect. \$\endgroup\$ Jan 3, 2021 at 22:46
And which i would to know is the capacitor role in that circuit, According to what I understood is that capacitor role is Cut down an amount of voltage by acting as closed circuit During capacitor charging,
No. The capacitor will charge to the peak mains voltage and is intended to maintain the DC voltage at a high enough value to allow the switching regulator to work during the low voltage periods of the mains voltage.
Current will flow of the following circuitry requires it. As drawn no current could flow as there is no return path.
Incorrect. Current flow can be calculated by Ohm's law, V = IR or I = V / R. At a lower voltage a lower current will flow.
Tip: please learn to punctuate and capitalise your writing properly. Your question required several passess to understand it and I'm not sure that I've understood it correctly.
