Q1: how much current can I draw from such a combination? 1A, 16A, 17A...?
If you put two power supplies in series, then the maximum current will be that of the weakest supply (in your case, 1A).
Q2: I understand that grounds must be isolated on the DC side, does this apply to the AC side of the PSUs? (Earth/ground or neutral?)
If both your power supplies have the negative terminal internally connected to Safety Earth, then you can't wire them in series because that would connect the negative terminals of both supplies together and cause a short circuit. So you should check with a multimeter if this is the case.
