This circuit I am using to drive a speaker is acting strangely.
Case 1: When I connect the 3.3 volts source from the Nucleo board it works fine as expected (in terms of the sound.) When I check the voltage across source it is 3.1 to 3 volts. A drop of only .2 to .3 volts.
Case 2: When I connect the GPIO output pin 3.2 volts as a source to the circuit, the speaker sounds very low. When I check the voltage at the GPIO pin it is 2.1 to 2 volts. It drops nearly 1 volt.
Why is it dropping so much voltage? Due to this speaker does not sound as expected.
What is the issue? Can I resolve this?
Edit: The GPIO is from a BlueNRG-1 chip.
