I saved and opened this data from my oscilloscope:
How to plot the real scale waveform data? Do I have to multiply it with vertical scale?
And what about the time? What to do if I want to plot the waveform data in the time domain? Since there's no time data and all I have is the sample period, horizontal scale and position.
here's the waveform from the oscilloscope display Screenshot from oscilloscope display
Thanks!!
  • \$\begingroup\$ It might help if you show a picture of the scope display also. \$\endgroup\$ – Andy aka Jan 8 at 13:51
  • \$\begingroup\$ You right! will you kindly check my edit? @Andyaka \$\endgroup\$ – Ramanda Nvl Jan 8 at 14:07
    \$\begingroup\$ Why don't you just plot a graph in excel and it will all become absolutely clear. \$\endgroup\$ – Andy aka Jan 8 at 14:10
  • \$\begingroup\$ The X axis will be the number of sample 1-500. I want to plot it in time domain, can I? \$\endgroup\$ – Ramanda Nvl Jan 8 at 14:14
  • \$\begingroup\$ Make a graph in your spreadsheet. This site isn't for teaching how to do that. \$\endgroup\$ – Andy aka Jan 8 at 14:20
You can do that, or use another factor based on scope probe attenuation or other factors that make sense for your ultimate objective.
The sample period should give you what you need.
Just use your eyes and brain and look at what you see: -
Then using excel (that's where your data appears to be) plot a graph of that data. This site isn't here to teach anyone how to use excel (or a spreadsheet) so that bit is up to you.
