I'm playing with the blue pill.
Here I run TIM2 and enable the DMA on its update event, according to Table 78 of RM0008, the DMA channel I should use is channel 2 on DMA1. Then I want the DMA to update TIM1.CCR1.
But I cannot get it working around DMA part. Here is the code:
#include <libopencm3/stm32/rcc.h>
#include <libopencm3/stm32/gpio.h>
#include <libopencm3/stm32/timer.h>
#include <libopencm3/stm32/dma.h>
#define PHASE_SIZE 10
const unsigned short PWM_phase[PHASE_SIZE] = {
1, 11, 21, 31, 41, 51, 61, 71, 81, 91
int main(void) {
// setup TIM1 as the main output
rcc_periph_clock_enable(RCC_TIM1);
rcc_periph_clock_enable(RCC_GPIOA);
rcc_periph_clock_enable(RCC_AFIO);
gpio_set_mode(GPIOA, GPIO_MODE_OUTPUT_50_MHZ, GPIO_CNF_OUTPUT_ALTFN_PUSHPULL, GPIO8);
timer_set_mode(TIM1, TIM_CR1_CKD_CK_INT, TIM_CR1_CMS_EDGE, TIM_CR1_DIR_UP);
timer_set_oc_mode(TIM1, TIM_OC1, TIM_OCM_PWM1);
timer_enable_oc_output(TIM1, TIM_OC1);
timer_enable_oc_preload(TIM1, TIM_OC1);
timer_enable_break_main_output(TIM1);
timer_set_oc_value(TIM1, TIM_OC1, 30);
timer_set_period(TIM1, 120);
timer_enable_counter(TIM1);
// setup DMA
rcc_periph_clock_enable(RCC_DMA1);
dma_set_peripheral_address(DMA1, DMA_CHANNEL2, (uint32_t)TIM1_CCR1);
dma_set_memory_address(DMA1, DMA_CHANNEL2, (uint32_t)&PWM_phase[0]);
dma_set_number_of_data(DMA1, DMA_CHANNEL2, PHASE_SIZE);
dma_set_priority(DMA1, DMA_CHANNEL2, DMA_CCR_PL_MEDIUM);
dma_set_read_from_memory(DMA1, DMA_CHANNEL2);
dma_set_memory_size(DMA1, DMA_CHANNEL2, DMA_CCR_MSIZE_16BIT);
dma_set_peripheral_size(DMA1, DMA_CHANNEL2, DMA_CCR_MSIZE_16BIT);
dma_enable_memory_increment_mode(DMA1, DMA_CHANNEL2);
dma_disable_peripheral_increment_mode(DMA1, DMA_CHANNEL2);
dma_enable_circular_mode(DMA1, DMA_CHANNEL2);
dma_enable_channel(DMA1, DMA_CHANNEL2);
// setup TIM2
rcc_periph_clock_enable(RCC_TIM2);
timer_set_mode(TIM2, TIM_CR1_CKD_CK_INT, TIM_CR1_CMS_EDGE, TIM_CR1_DIR_UP);
timer_set_period(TIM2, 100);
timer_set_dma_on_update_event(TIM2);
timer_enable_counter(TIM2);
while(1) {
//__asm("nop");
I can read through openocd that the TIM2 is ticking. But when the RCC_DMA is enabled, I cannot read DMA registers anymore (may be they are busy?).
Is there something wrong with DMA setup? Thank you!
And there is no libopencm3 tag yet?
