I have some technical drawings and I am looking for the name of a pair of components (or maybe two disctinct components) whose symbols I cannot identify. I understand one is a type of switch controlled by the other component which is connected to a NI-6008 USB card. The two are drawn separately but I do not know if they are linked in reality, simply avoiding additional wires on the schematic.
What are the following symbols?
    \$\begingroup\$ Relay coil and relay contact - go google electrical relay \$\endgroup\$
    Commented Jan 9, 2021 at 17:33
  • \$\begingroup\$ @Andyaka Thank you! If you post it as an answer, I will accept it. \$\endgroup\$
    – AlMa
    Commented Jan 9, 2021 at 17:35
  • \$\begingroup\$ Done (hopefully) @juca \$\endgroup\$
    Commented Jan 9, 2021 at 17:38
  • \$\begingroup\$ Andy’s the fast shooter \$\endgroup\$ Commented Jan 9, 2021 at 17:47
Try this: -
There are many variations on this general theme that you should you google: -
Picture from here.
Picture from here
