I'm learning JFET self biasing. what I've understood so far is the resistor R_s is used to create a bias voltage as shown. since no gate current flows that means no current in R_G so the potential of the gate is Zero because it is like connecting the gate with the zero potential (ground), then what is the purpose of the resistor R_G? they could have directly shorted the gate with ground, why this extra resistor?
\$\begingroup\$ Why do you say no current in \$R_G\$? \$\endgroup\$– HearthJan 10, 2021 at 16:17
\$\begingroup\$ @Hearth JFET is a voltage controlled device so is there any current in gate? I am not sure, I am learning \$\endgroup\$– SayanJan 10, 2021 at 16:18
1\$\begingroup\$ See the answer below. There's no (significant, DC) current into the gate, but there is still current in that resistor. \$\endgroup\$– HearthJan 10, 2021 at 16:24
1 Answer
There will be current in that resistor, and there also will be no (DC) current into the gate. Here, take a look:
\$\begingroup\$ great! this is what I was thinking, but i was not sure. thank you. \$\endgroup\$– SayanJan 10, 2021 at 16:25
\$\begingroup\$ so the resistor's purpose is to vary the voltage drop in accordance with signal so that different GS voltage produces, right? \$\endgroup\$– SayanJan 10, 2021 at 16:29
2\$\begingroup\$ @Sayan Not exactly; if the signal is a voltage it doesn't need that resistor. But the resistor keeps the gate pulled to 0 volts if the signal is disconnected; leaving a FET's gate floating is poor form. \$\endgroup\$– HearthJan 10, 2021 at 16:30
