I am implementing PID control in c++ to make a differential drive robot turn an accurate number of degrees, but I am having many issues.
Exiting control loop early due to fast loop runtime
If the robot measures its error to be less than .5 degrees, it exits the control loop and consider the turn "finished" (the .5 is a random value that I might change at some point). It appears that the control loop is running so quickly that the robot can turn at a very high speed, turn past the setpoint, and exit the loop/cut motor powers, because it was at the setpoint for a short instant. I know that this is the entire purpose of PID control, to accurately reach the setpoint without overshooting, but this problem is making it very difficult to tune the PID constants. For example, I try to find a value of kp such that there is steady oscillation, but there is never any oscillation because the robot thinks it has "finished" once it passes the setpoint. To fix this, I have implemented a system where the robot has to be at the setpoint for a certain period of time before exiting, and this has been effective, allowing oscillation to occur, but the issue of exiting the loop early seems like an unusual problem and my solution may be incorrect.
D term has no effect due to fast runtime
Once I had the robot oscillating in a controlled manner using only P, I tried to add D to prevent overshoot. However, this was having no effect for the majority of the time, because the control loop is running so quickly that 19 loops out of 20, the rate of change of error is 0: the robot did not move or did not move enough for it to be measured in that time. I printed the change in error and the derivative term each loop to confirm this and I could see that these would both be 0 for around 20 loop cycles before taking a reasonable value and then back to 0 for another 20 cycles. Like I said, I think that this is because the loop cycles are so quick that the robot literally hasn't moved enough for any sort of noticeable change in error. This was a big problem because it meant that the D term had essentially no effect on robot movement because it was almost always 0. To fix this problem, I tried using the last non-zero value of the derivative in place of any 0 values, but this didn't work well, and the robot would oscillate randomly if the last derivative didn't represent the current rate of change of error.
Note: I am also using a small feedforward for the static coefficient of friction, and I call this feedforward "f"
Should I add a delay?
I realized that I think the source of both of these issues is the loop running very very quickly, so something I thought of was adding a wait statement at the end of the loop. However, it seems like an overall bad solution to intentionally slow down a loop. Is this a good idea?
turnHeading(double finalAngle, double kp, double ki, double kd, double f){
    std::clock_t timer;
    timer = std::clock();
    double pastTime = 0;
    double currentTime = ((std::clock() - timer) / (double)CLOCKS_PER_SEC);
    const double initialHeading = getHeading();
    finalAngle = angleWrapDeg(finalAngle);
    const double initialAngleDiff = initialHeading - finalAngle;
    double error = angleDiff(getHeading(), finalAngle);
    double pastError = error;
    double firstTimeAtSetpoint = 0;
    double timeAtSetPoint = 0;
    bool atSetpoint = false;
    double integral = 0;
    double derivative = 0;
    double lastNonZeroD = 0;
    while (timeAtSetPoint < .05)
        updatePos(encoderL.read(), encoderR.read());
        double dt = currentTime - pastTime;
        double proportional = error / fabs(initialAngleDiff);
        integral += dt * ((error + pastError) / 2.0);
        double derivative = (error - pastError) / dt;
        //FAILED METHOD OF USING LAST NON-0 VALUE OF DERIVATIVE
        // if(epsilonEquals(derivative, 0))
        //     derivative = lastNonZeroD;
        // else
        //     lastNonZeroD = derivative;
        double power = kp * proportional + ki * integral + kd * derivative;
        if (power > 0)
            setMotorPowers(-power - f, power + f);
        else
            setMotorPowers(-power + f, power - f);
        if (fabs(error) < 2)
            if (!atSetpoint)
                atSetpoint = true;
                firstTimeAtSetpoint = currentTime;
            else //at setpoint
                timeAtSetPoint = currentTime - firstTimeAtSetpoint;
        else //no longer at setpoint
            atSetpoint = false;
            timeAtSetPoint = 0;
        pastTime = currentTime;
        pastError = error;
    setMotorPowers(0, 0);
turnHeading(90, .37, 0, .00004, .12);
  • \$\begingroup\$ Regarding overshoot, there are several sources of it, but one of them is inherent in PI. For the common situation of a plant that is an integrator or dominant-pole, PI (always has a zero in the feedforward) goes through to become an unwanted zero to passband. The closed-loop zero can be avoided by putting the zero in the feedback path rather than the feedforward path. In digital, keep the Ki term, reduce or eliminate the Kp term, and replace it with d/dt(output) added into the integrator. It's the old Phelan trick, can be quite nice, easy to tune a zero-overshoot controller in many cases. \$\endgroup\$
    – Pete W
    Jan 10 at 21:59
  • \$\begingroup\$ for position control, depending on what you are actually controlling (speed or force), the plant may have double pole. If so, PID is not that great... \$\endgroup\$
    – Pete W
    Jan 10 at 22:04
  • \$\begingroup\$ re: adding delay? usually makes things worse, and there is a better solution \$\endgroup\$
    – Pete W
    Jan 10 at 22:08
  • \$\begingroup\$ Skip a fixed number of increments for the derivative calculation. \$\endgroup\$
    – Chu
    Jan 10 at 23:22
  • \$\begingroup\$ @PeteW I am controlling motor power (voltage). I don't know what category that would fall under or if double pole applies. \$\endgroup\$
    – droiddoes9
    Jan 10 at 23:31
