I have the schematic for an 8 channel 24V to 5V optocoupler board I purchased. It uses the EL817.
My input is an open collector input pulled up with 10K to 5V.
I can't drive it to gnd to trigger my input. It only goes down to 1.79V.
I would like to upload the schematic and my load if I can.
Thanks
    \$\begingroup\$ The module is similar to the jpeg just with leds on input and output. \$\endgroup\$
    – VIC
    Commented Jan 11, 2021 at 8:12
    \$\begingroup\$ How do I provide a link in my comments to the module and schematic? \$\endgroup\$
    – VIC
    Commented Jan 11, 2021 at 8:13
    \$\begingroup\$ I am trying to take a 13.8v or 0v input and convert it to +5v or 0v. The input of the circuit I am trying to switch between +5v and 0v is just a collector pulled with 10K to +5vcc and the emitter is connected to gnd. When the EL817 goes low it will only drive it down to 1.87 v ???? \$\endgroup\$
    – VIC
    Commented Jan 11, 2021 at 8:37
    \$\begingroup\$ Why can't you upload it? What's stopping you? \$\endgroup\$
    Commented Jan 11, 2021 at 9:50
    \$\begingroup\$ the title of your post should be about an electronics problem, not about the usage of this website ... site usage questions belong at electronics.meta.stackexchange.com \$\endgroup\$
    – jsotola
    Commented Jan 11, 2021 at 17:10
