I'm trying to find out if there is any way to control the CC lines on a USB-C from an android app. I need to signal to my embedded gadget some event, instigated from an android app. I can't find any details on the phy layer of USB for android. any suggestions?
  • \$\begingroup\$ You want to use the CC pin as an IO? \$\endgroup\$
    – Dejvid_no1
    Commented Jan 11, 2021 at 20:52
  • \$\begingroup\$ I'd like to create some trigger-worth signal that is created by the android app. in my readings, the best case scenario would be to toggle the cc lines, like a DRP should be able to do. that way my external device can detect the state change and go do something. \$\endgroup\$
    – Darren
    Commented Jan 11, 2021 at 22:18
I doubt the CC pins are exposed to applications since they're an internal part of the USB connection and not something an application should have access to. Instead, a better option would be to use the USB data pins:
https://code.google.com/archive/p/android-serialport-api/wikis/android_to_rs232_guideline.wiki
This is officially supported and much more flexible.
  • \$\begingroup\$ good suggestion. I could use D+/D-. But I'd like to have an obvious event signal which I could use as GPIO for another mcu. that's what I was thinking doing the DRP swap for switching the CC lines would be a good candidate. Is there a forum for asking low level android questions? worst case scenario, I could do some root fix if it gave me control of the usb protocol pins. \$\endgroup\$
    – Darren
    Commented Jan 12, 2021 at 23:40
  • \$\begingroup\$ If the drivers for your chipset have source code available you could look into how that signaling works. It may not be exposed at all though. \$\endgroup\$ Commented Jan 13, 2021 at 0:05
  • \$\begingroup\$ the signal must be instigated by the user in an android app. that's what I'm trying to dig down into. but it doesn't have obvious exposure from android dev documentation. \$\endgroup\$
    – Darren
    Commented Jan 13, 2021 at 0:41
  • \$\begingroup\$ You won't be able to do this from within an Android app. \$\endgroup\$ Commented Jan 13, 2021 at 2:14
