I'm currently redesigning a board that has a high failure rate. The design consist of three power rails 3.3v 12v and 24v
  • 3.3v is coming from an USB powered Nucleo STM dev board
  • 24v is my input power from a DIN rail PSU and is distributed via a copper plane on the entire board.
  • 12v is generated with a LDO from the 24v rail.
  • GND is all interconnected with a copper ground plane.
The board has six Geckodrive stepperdrives mounted on it, those are definitely causing the failures.
Geckodrives have two ground pins, one for logic and one for powering the steppermotors. They say I should first of all route the 24v as a track to each Geckodrive instead of using a 24V powerplane. (star network) And also never interconnect the two ground inputs.
So what I was planning to do is giving all 3.3v & 12v devices + Geckodrive logic ground the ground of my Nucleo board. And the Geckodrive power grounds are connected to my 24v PSU ground.
But how to split the ground at the LDO? It has only one GND pin. If I give it PGND do my 12v powered device perform perfectly by having the GND of Nucleo board?
I'm only allowed to share a snippet of the PCB design that shows how the Geckodrives are interconnected. enter image description here
At the left you have the logic GND of the Geckodrive. At the right the Power GND. Both grounds are connected to same GND plane The brown polygon is the 24V for all six Geckodrives to my surprise it barely makes a connection to the desired Geckodrive pin!!
So in this design all grounds are interconnected. And one big 24V polygon is feeding all six Geckodrives (so far from star formation)
    \$\begingroup\$ You need to shape the ground place. There are a lot of answers here on that; here is one I did some time ago. Even though it is a different application, the basic advice remains the same. electronics.stackexchange.com/questions/185306/… \$\endgroup\$ Jan 12, 2021 at 16:48
    \$\begingroup\$ What kinds of failures are you exhibiting? \$\endgroup\$
    – crasic
    \$\begingroup\$ Show a picture of the board and schematic, is it four layer? Most often the problem is common mode voltage noise or improper routing. Splitting grounds will probably cause more problems (there are not many reasons that one should split a ground and there are much better ways to solve problems than split grounds). It's most likely overvoltage that is causing the problem, have you put a scope on a board to check the voltage on the rails when the motors are running? \$\endgroup\$
    – Voltage Spike
    Jan 12, 2021 at 16:55
    \$\begingroup\$ If the design is under NDA then hire someone who will sign the NDA. To answer the question requires a look at the schematic. Would you ask an animal surgeon to advise on a procedure without telling him the animal? \$\endgroup\$
    Jan 12, 2021 at 17:11
    \$\begingroup\$ Be aware that the energy of a signal is in the field between the signal track and the ground return. The energy is following the signal 100% in the ground plane and is only spreading a little bit wider than the track (due to the distance between team and ground layer). So in most case, if routing is propper, splitting ground is not necessary and might even amplify your underlying routing issue ( if your issue is really an issue of that, and not actually in the schematic itself - which nobody can help you with, without a schematic and boards layout) \$\endgroup\$ Jan 12, 2021 at 17:57
Pending an answer to my comment, I suggest you do not over think things and just make sure high power current return paths don't coincide with digital logic and other return paths, since ground current is the primary issue at hand for most ground related device failures (inductive coupling ), it should be relatively straight forward to determine where the highest current return is and focus efforts on those first, before a major redesign of the whole ground network.
Split ground is somewhat of a nuclear option , but logically classing and routing different signal returns is a good idea.
Ground coupling issues are categorized as typically inductive and capacitative, most people have enough good sense to make ground connections fat and low resistance.
Inductive coupling is associated with high current mixed sysyems, What happens is these produce voltage spikes on the ground net that impact all devices further up the ground chain, here star grounds are a popular solution, every "arm" of the star is inductively decoupled .
Source:Analog Devices MT-031
See also: https://www.ti.com/lit/slyt499
  • \$\begingroup\$ Yes, so ideally I give each of my Geckodrive 24V & PGND pin a routing track and let them meet as closest to my 24v PSU terminal connector as possible. Right? \$\endgroup\$ Jan 12, 2021 at 17:30
  • \$\begingroup\$ That could be one approach that may successfuly implement this design philosophy, but there are some caveats. You would have to present the details to get a design review. \$\endgroup\$
    – crasic
    Jan 12, 2021 at 17:33
  • \$\begingroup\$ I updates my question with a snippet (rest is NDA sensitive) hopefully this gives a bit more clearance \$\endgroup\$ Jan 12, 2021 at 17:47
  • \$\begingroup\$ At the same time this video was published :) youtu.be/vALt6Sd9vlY \$\endgroup\$ Jan 16, 2021 at 13:31
