The question might sound silly, but I hope experts can guide me on that particular issue. I am struggling for the last few months. I am a beginner in analog circuit design. When I follow a tutorial, I found that by observing a big transistor (MOS)-level circuit, they can say about node voltages, branch current, input and output resistance, and sometimes gain. My question is, without drawing a small-signal model of those circuits, how do people do that? Is this because they already solved many circuits by hand (I mean not using any simulator), and that is why a concept was built? Even when I try to draw a small-signal model for a big circuit I get lost due to the circuit's complexity. What is a good way to approach this kind of circuit?
I added the figure as an example circuit!
Thanks for your time!
Figure reference: https://www.hindawi.com/journals/apec/2014/274795/
A lot of it is simply seeing/solving circuits and subcircuits often, and being able to pull out those structures and consider their behavior in isolation. Even complex circuits tend to often decompose to a number of simpler elements, allowing a lot of behavior to be qualitatively described quickly, saving mathematical analysis for unfamiliar or unusual sub-structures.
These understandings of common subcircuits, of course, come from mathematically solving those subcircuits for behavior, typical operating point, input/output impedances, etc.
As an example for this circuit, one path of analysis that comes to mind is to:
  1. Assume all MOSFETs in saturation.
  2. Notice that Mk (likely strongly inverted) is giving a constant bias voltage to M3/M4 gates thus making M3/M4 matched cascodes for M1/M2.
  3. Attempt to pattern-match M1/M2 to a current mirror, noting that the gates don't connect to the drain so I might not be able to immediately make that simplification.
  4. Hand-wavily consider M1/M3 as if it were a single transistor with very high output impedance because a cascode structure behaves that way under the assumed conditions. Same for M2/M4.
  5. Now the two sides match a current mirror structure, with high output impedance thanks to the cascode.
At each step, I redraw the circuit (mentally or otherwise) and continue making simplifications/equivalences that seem to simplify it further.
Knowing the circuit's rough structure and behavior allows me to decide what stimuli make sense for it--it can now be simulated to supplement and verify the analysis. If I get unexpected results, I revise my analysis, simulate again, and so on until my understanding and expected/actual results converge.
    \$\begingroup\$ thanks a lot for taking the time to answer my question. I got the idea. \$\endgroup\$
    – Shu
    Jan 15, 2021 at 15:31
