I have a question regarding the manual type relay switch shown in the picture.
I need relay with dual coil-latching, I thought of using avmomentary toggle SPDT to turn the relay on and off, but I will not know the position of the lever of the switch (whether it is set or reset.) If I use a relay with a built in manual switch which is on the top of the relay, is it possible to set and reset the relay using that without needing any external momentary switches? If I use the normal one then I would need an additional digital latch or flipflop.
Please let me know if I can the manual switch type relay and also let me know if there are any disadvantages with the manual type relay switch.
