I am trying to identify the component (I believe is a varistor) in the image below (is from a blender). In another piece of the epoxy I was able to read 14. Should I assume is a 14d241K? Tks!
1 Answer
14d241K seems good for 110v and protect it against 220v.
But for urgent needs you can use any above your voltage or skip this component, if you already remember that 220v is bad for it.
\$\begingroup\$ Thank you very much! This will help me choose a replacement. \$\endgroup\$– LinoJan 16, 2021 at 17:24
/241K
,/241R
,/24TK
or/24TR
