Anyone know the connector size for the TPM port? I wanna take the 5vSB power from it. If it helps its a MSI B450+ Tomohawk.
Thanks!
P.S. I have searched but TPM means too many things!
Edit: WHOOOOOPS! Yes I meant TPM instead of TMP!
  • \$\begingroup\$ You might want to make it clear it's a connector on a PC motherboard. \$\endgroup\$
    – Justme
    Jan 16, 2021 at 17:14
Do you mean TPM? Looks like an Amphenol iPN FCI 20021321-00014D4LF is the mating connector 1.27mm pitch 2 x 7 with a key.
Pinout is in the Mobo manual, 3 power supply rails available, but standby is not 5V.
  • \$\begingroup\$ Thank you! Not only did I mean TPM instead of TMP I also means 3vSB power! \$\endgroup\$ Jan 16, 2021 at 17:22
I could be wrong but it looks like a 0.1"(2.54mm) spacing, something that is quite standard on almost everything from raspberry pi(s) to arduinos. So a pcb mount connector would look like S7074-ND from digikey.
This site is temporarily in read-only mode and not accepting new answers.
Not the answer you're looking for? Browse other questions tagged .
