I'm trying to build a diy pedal adapter for my digital piano. The piano has a 6x1 2.54mm pitch female socket header. It has a serrated side, and a little notch on the other side to secure the male connector.
Pedal female connector
Male connector:
Pedal male connector
A schematic view of the connectors:
Schematic connector view
What is the name of this particular pin header connector?
  • \$\begingroup\$ You should take it out and do a better photo. \$\endgroup\$ Jan 17, 2021 at 13:04
  • \$\begingroup\$ I know. Unfortunately I don't have access to the male header. These pictures are everything I could find online. \$\endgroup\$ Jan 17, 2021 at 14:33
  • \$\begingroup\$ replace the connector with a DB9 connector ... duckduckgo.com/?q=db9+connector&iax=images&ia=images \$\endgroup\$
    – jsotola
    Jan 17, 2021 at 17:43
It's a JST SM connector. I ordered samples of this connector, tested and confirmed this is the one.
