1st attempt
I have a problem. I built the FM demodulator circuit, but i am not sure if this signal is demodulated. This was my first attempt which following an answer, resulted in a 2nd attempt further down.
enter image description here This is my input - fm modulated signal and output : enter image description here
EDIT - 2nd attempt following advice in an answer:
Thanks for the help in advance!
  • \$\begingroup\$ Maybe? There isn't really any way to tell anything from those graphs. \$\endgroup\$ – hobbs Jan 17 at 17:47
  • \$\begingroup\$ ahh nope. just looks attenuated \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Jan 17 at 17:47
  • \$\begingroup\$ Can't see much difference at that resolution apart from amplitude. Post the schematic of the circuit you're testing \$\endgroup\$ – Neil_UK Jan 17 at 17:49
  • \$\begingroup\$ Ok, I'm adding circuit diagram. \$\endgroup\$ – Chuckyy Jan 17 at 17:52
  • \$\begingroup\$ This is ratio detector, I mean I try build... \$\endgroup\$ – Chuckyy Jan 17 at 17:53
Firstly, you should try and draw schematics so that they can be displayed properly: -
Secondly, you should not use the Rser statement because it hides the important fact that there is 60 Ω in series with the AC source. Well, I say it hides it; I'm not actually sure what it does with LTspice so, better to explicitly show it as a resistor.
And, with Rser at 60 Ω, L = 40 μH and C = 1 nF you get a rather shallow band pass filter effect that, might as well not be present at all: -
Then, the main killer is that you have applied a coupling factor of unity to all the inductors in your transformer, so, it won't work properly. Try something arounf 0.5 instead of 1.
