I have a Sugon T26 soldering station.
It has an European 2 pin plug, I have a 3 pin adapter for it.
As far as I am aware there will be no ground connection using this method.
It comes with a ground connector on the station, crocodile clip style.
Where should I connect the clip? (I am situated at home.)
I have no access to a ground other than in the wall socket.
Am I better off trying to source a 3 cable wire for the power supply and fixing a standard UK plug to it?
