Ive started a new job at a startup and am working on a BOM for a box build with a couple of PCBs and wire harnesses inside. Im in a bit of an impasse about how best to define wire harnesses in the BOM. In my previous job, we made standalone PCBs for OEM markets, where I only defined PCB mounted components, and never dealt with wire harnesses. What im trying to get my head round now though is in this instance where we will order a spool of wire, and then cut it to required lengths to then be crimped and inserted into a connector, should the spool be a BOM item, and then the cut wires be entered as sub-assemblies created from it? Or should the cut wires be BOM items, and they simply reference the relevant spool from a supplier?
4\$\begingroup\$ The harness is a sub-assembly by itself and needs to have its own part number with schematics and assembly instruction. In the BOM you list its part number. But surely you can come up with some other arrangement with a specific manufacturer. \$\endgroup\$ – Eugene Sh. Jan 18 at 16:08
1\$\begingroup\$ If at all possible, outsource the wire harness. Making wire harnesses is very tedious. You may still need to make a drawing, but it will be less critical in the sense that the vendor will use the drawing to make samples, which you can approve or provide feedback on. Once you get it ironed out then it is just a single orderable part and a single part number in your database. You can include the wire harness in the PCB assembly BOM, or if it makes more sense, as a line item in a mechanical assembly. \$\endgroup\$ – mkeith Jan 18 at 16:48
\$\begingroup\$ So it will be outsourced, this BOM is going to an assembly house, who will make the harnesses and do the box build. I think I just need to wait on them responding to my email with their preference and guidance. Id posted this question here simultaneously out of curiosity at what stack exchange had to say. \$\endgroup\$ – cstanto Jan 18 at 16:53
\$\begingroup\$ It is always hard at first. You need to include the p/n for the harness in the BOM you send to the assembly house initially. Otherwise they won't even know they are supposed to supply it. If you do not yet have an orderable p/n for it, then you will have to do your best to describe it with a drawing that calls out p/n for crimps, wires, housings, etc so they can make it (or they may outsource it themselves and hide all the details from you which is not necessarily a bad thing). \$\endgroup\$ – mkeith Jan 18 at 17:00
1\$\begingroup\$ An assembly is inherently a tree-like entity. The root is the final assembly, its subtrees are sub-assemblies having an internal part number. The leaves are part numbers for existing/off-the-shelf products. This is a bit of idealization, though. \$\endgroup\$ – Eugene Sh. Jan 18 at 17:07
It's typically best if the BOM reflects the assembly process. Start with the final product (or whatever goes in the box to be shipped) and work backwards through the subassembly.
If the harness gets build on the final line, than only the parts (wire, crimps, etc.) should be in your BOM. If it shows up on the line pre-assembled, than it's a subassembly with it's own part number and sub-assembly BOM.
Most BOM management tools allow you to structure the BOM this way and also create a "flat" view, where all parts are listed.
\$\begingroup\$ So the harness will be built on the final line. For the wires in the BOM, should I define it as it will be in the harness, ie. <our part number> <QTY in the harness> <"50mm 20AWG PVC coated wires"> <manufacturers PN> etc, where the manufacturers part number references the spool they supply of x number of metres, and our assembler just orders that and cuts the 50mm wires from it, or reference the spool explicitly as a component and then derive the cut to length wires as child components? \$\endgroup\$ – cstanto Jan 18 at 16:32
\$\begingroup\$ If your company is ACME, you would want the wire harness to have a single unique ACME part number. Under that part number, there may be mulltiple manufacturer part numbers from different manufacturers that are all considered interchangeable as far as assembly goes. So ACME_PN contains multiple MFG_PN. Each MFG_PN has an associated MFG. Just like resistors. ACME p/n 111-3456 is a 10 Ohm 0805 5% resistor. Under that p/n, MFG1 is samsung, MFG2 is yageo, etc, and for each MFG you also have the MFG_PN. \$\endgroup\$ – mkeith Jan 18 at 16:54
Often the wire harness will have its own part number which you can ask for on a BOM. This treats the harness as a single component from the BOM point of view.
The description for that part number will refer to the harness's own drawing number, BOM, and assembly procedure (and possibly drawings for the jig needed to assemble it). Your spool of wire will then be on the harness BOM, not the main product BOM.
It can then be built separately and held in stock - or even built by another company - or built on the production line, according to whichever suits your process.
Keeping it a separate component can simplify build variants : revisions 1,2 use harness part number HARN003 while revision 3 uses HARN007, which can also be shared with (some other similar product)
Each cut wire can have a fractional quantity of the bought in spool. BoM software easily deals with this. The fractional part of the bought spool would be a BoM item but be defined as bulk issue if the cable assembly is built as and when it is needed. Defining the spool as bulk issue means the spool can be available without "booking it from stores".
If you are taking the spool and cutting wires that go back into stock for later use when building the cable assembly, then the cut wires need to be given a part number and the cable assembly BoM will refer only to them.
The short answer is, use a ‘multi-level’ BOM. Each subunit in the BOM has its own BOM and design data that report in to the part number for that subunit. Add as many levels as needed for your product, including a finished good in a carton.
Another task you face is creating a part number system. As you do that, think about how to distinguish items as they relate to the BOM level they belong to as well as their type. You can sort of encode that into a categorized part number, or choose not to and just assign arbitrary numbers as you need them and bury that information in the record for the part number. Doing the former does make things a bit easier, if done sensibly.
Cable assemblies call out the need for a part number category: bulk materials, such as wire. You would reference that in your BOM with a length quantity, rather than call out each length of wire as an item. MRP systems are set up to deal with this.
