Suppose we connect two transmission lines with characteristic impedances \$Z_1\$ and \$Z_2\$. The reflection coefficient looking into the transmission line with impedance \$Z_2\$ is $$ \Gamma=\frac{Z_2-Z_1}{Z_1+Z_2}. $$ Now consider the case where both lines are two coaxial conductors. For both lines, the impedance may be calculated by $$ Z=\frac{1}{2\pi}\sqrt{\frac{\mu}{\epsilon}}\ln{\frac{D}{d}}, $$ where \$\mu\$ and \$\epsilon\$ are, respectively, the magnetic permeability and dielectric constant of the dielectric between the two conductors, \$D\$ is the inner diameter of the outer conductor, and \$d\$ is the outer diameter of the inner conductor. Assume the dielectric is the same between the two transmission lines, but for one of the transmission lines, \$D\$ and \$d\$ are both smaller than the corresponding values for the other by the same factor. In this case, \$\frac{D_1}{d_1}=\frac{D_2}{d_2}\$, \$Z_1=Z_2\$, and the reflection coefficient \$\Gamma=0\$.
Based on this result alone, I would expect a voltage wave incident on the interface between the two lines to undergo no reflection. On the other hand, there is clearly a geometrical discontinuity at the interface, which I would intuitively expect to produce a reflection. Is my intuition wrong or am I missing something?
