I'm designing a diode limiter for audio use where the signal is high passed through a discrete transistor circuit. After the diode stage the signal would need its low end restored and I'm struggling to find a way to archieve a flat response at the output.
I initially had three opamp LPFs configured so that frequencies above fc will be at unity gain. That's the only way I could remove the low end slope, though it seemed a bit sketchy and unprecise as it would create quite a hearable bump (5db) at around 200Hz.
Now I thought to copy the same exact HPF circuit that I use at the input and put it in the negative feedback of the opamp. Theoretically in that way the opamp will have a frequency response that will be exact opposite of the one in the feedback loop HPF?
Anyway it doesn't seem to work, somehow the low end it's still not flat but a slope going to -30dB.
Before I go crazy trying to make it work, does anybody know if I made any wrong assumptions/ or know of a better way to solve the freq response drama?
Cheers! HPF function schematic block diagram
  • \$\begingroup\$ Comments are not for extended discussion; this conversation has been moved to chat. \$\endgroup\$ – Voltage Spike Jan 22 at 3:51
