I’m looking for the name of the component that act like a relay but instead of using a coil to generate a magnetic field that moves the relay « arm » it uses a LED and a photosensor.
It allows to isolate a high voltage of a circuit from a low voltage.
Thanks a lot!
  • \$\begingroup\$ I think you're looking for an opto-isolator (aka optocoupler). \$\endgroup\$ Commented Jan 20, 2021 at 16:52
Optocoupler, optoisolator, solid state relay, opto-triac.
  • \$\begingroup\$ Optocoupler! That’s what I was looking for ! Thanks a lot!! \$\endgroup\$
    – Dominique
    Commented Jan 20, 2021 at 17:08
Solid-state relay is the term you are looking for for high power devices.
Opto-isolator for small currents.
    \$\begingroup\$ A solid-state relay is just an optocoupler with aspirations. \$\endgroup\$
    – Hearth
    Commented Jan 20, 2021 at 16:55
