I am considering purchasing a smart light switch which does not require a neutral wire and instead works with a bypass capacitor parallel to the load lamp. This switch would control two lamps in series, however, and it will not be easy to install the capacitor such that it is connected to the one side of the first lamp and the second side of the second lamp. Can I use two capacitors (of double value each?) each connected parallel to each of the two laps?
Instead of this:
smart switch with bypass capacitor
This:
smart switch with two bypass capacitors
    \$\begingroup\$ It concerns me that you have two lamps wired in series. What would happen if one was (say) 5 watt rated and another placed in series was 60 watt rated. Do you know what will happen? \$\endgroup\$
    Jan 22 at 12:22
  • \$\begingroup\$ They’re two identical lamps in a kitchen hood which came with the apartment and one switch controls them both, so I suppose they’re probably parallel then based on what you’re saying, which means one bypass capacitor would be enough \$\endgroup\$
    – user274648
    Jan 22 at 13:07
    \$\begingroup\$ If you remove one lamp, does the other still shine? \$\endgroup\$
    Jan 22 at 13:11
