I'm using XTR305 for Analog output. Below is the circuit for the same. After successful output from DAC which is input to XTR305, I'm not getting the output voltage. Can someone help me with that? enter image description here
  • \$\begingroup\$ Do you have the thermal pad connected to V-? \$\endgroup\$ Jan 23, 2021 at 5:54
  • \$\begingroup\$ @SpehroPefhany Yes. Does XTR305 need bipolar supply? \$\endgroup\$
    – Fatpanda
    Jan 23, 2021 at 6:17
  • \$\begingroup\$ I've combined all the error flags and used a single signal to microcontroller. Will this cause a problem? \$\endgroup\$
    – Fatpanda
    Jan 23, 2021 at 7:38
