It's been a while since I've done analog circuit theory, and I'm trying to interpret the 2nd gain stage sub-circuit in this schematic for a guitar pedal:
I'm not sure if I'm approaching the circuit correctly, but I noted that if the magnitude of Vout is less than the forward-bias of the diode(s), this becomes a 2nd-order bandpass filter structure, where the high cutoff frequency is controlled by the gain potentiometer.
Does this mean that this is essentially just a bandpass filter that also clips the output?
This article kind of explains the sub-circuit from a different approach, and I can't tell if their analysis contradicts mine or not:
[...] there's a cap in series with the Rin resistor. This forms a high-pass filter with a corner frequency of ~72Hz, so all of your bass will pass through. Then there's a set of LEDs used for soft clipping and a 47pF cap to smooth out some of the treble content. Overall, this looks a lot like the tube screamer clipping section. The major difference is that it uses LEDs (a common TS mod) and the corner frequency on a Tube Screamer is much higher, cutting out a lot of bass (~720Hz).
Yes, its essentially doing this but with the gain of the opamp. So the output is clipped which is useful if the next stage (or ADC) has a smaller input voltage range.
Source: http://technlab.blogspot.com/2018/07/study-of-diode-as-clipper-clamper.html
The easiest thing to do would be to just simulate that stage in spice (or Lt spice) and do a DC operating point simulation. (I might add one later if I have time).
One way to analyze these is to do a regular gain analysis without the diodes and then draw the point where the diodes begin to turn on, and at that point the output will start to be clipped.
  • \$\begingroup\$ Thanks! I actually just did the AC analysis in qucs and confirmed the frequency response was as expected, but I haven't done a DC point sim yet \$\endgroup\$
    – Nick Nagy
    Jan 25, 2021 at 22:00
  • \$\begingroup\$ Oh, if you do a DC sim you might want to short C8, just saw that. The DC will be centered around zero because of C8, but that will give you a better idea \$\endgroup\$
    – Voltage Spike
    Jan 25, 2021 at 22:07
  • \$\begingroup\$ In my AC sim the gain magnitude in the bandpass is 46.5 (Rgain + R10 / R9), even with the diodes in place. Is that just because clipping / non-linearities are ignored in AC sweep simulations? EDIT: just re-read the last sentence in your original answer which makes me think yes \$\endgroup\$
    – Nick Nagy
    Jan 25, 2021 at 22:31
