I am using a whole array of IXYS CPC7524 high-voltage switches in one of my designs. Although the design of this specific switch is not made explicit, its characteristics and other products in the IXYS product line (such as the CPC1511) leads me to believe that the pass elements are quite probably pass NMOS devices with additional thermal protection circuitry.
The application requires fast switching of voltage/current across the switches (which remain constantly turned on) and we are getting very problematic behavior out of them. This conceptual schematic shows how the switches are being used:
Q1 is used as a saturated switch and M1 as a current source. The slew rate in all nodes was measured and it never exceeds 100V/µs (the CPC7524 is specified in excess of 1500V/µs), however this is what we see on those nodes (everything is turned off after 600µs from the trigger):
Switch opening and Drain chatter
Which clearly shows the switches enter a high-impedance state as soon as the NFET turns on, and takes as much as 250µs to reduce their impedance to the point the circuitry becomes properly biased (the chatter in the Drain node (CH1_R) shows instability due to the gain provided by the presence of the switch impedance).
In other scenarios (e.g., higher voltage or a shorter delay before NFET turn-on), the switches simply latch-up a temperature fault (an undocumented behavior) and open the circuitry requiring a power-cycle.
NOTE 1: this is a conceptual schematic. The details of the application are not very relevant. Suffice it to say that I need something that behaves just as a physical and slow mechanical switch or relay, connecting two sides of a circuit that has large fast-varying waveforms. Not a dynamically varying resistor, which is what I am getting with these switches.
NOTE 2: This is implemented in several interconnected PCBs with high-voltage edge-card connectors. We investigated all possibilities (including the possibility of inductive coupling between nearby traces) before narrowing down the problem to the switches. So yes, we are 100% certain the switches are the problem. And we understand the problem well enough to get the switches to predictably misbehave at will. The rest of the circuitry works exactly as designed.
Question
As these switches are clearly not acceptable for our application, before we undergo a redesign using large, cumbersome, and power hungry reed relays (note there are large numbers of these switches), does anyone know if a simpler Solid-State Relay, such as the Vishay VOR2142A8 would present the same kind of problems?
Can anyone suggest a better solution?
  • \$\begingroup\$ Comments are not for extended discussion; this conversation has been moved to chat. \$\endgroup\$
    – Voltage Spike
    Commented Jan 29, 2021 at 17:19
  • \$\begingroup\$ don’t modulate off! chose a low current such that your response will be as you expect instead Coss x N x R leakage = xxx us like <5% or so. Turn off a current sink will be a problem with this design. similar problems occur with other designs like this. \$\endgroup\$ Commented Apr 2, 2021 at 5:42
  • \$\begingroup\$ @TonyStewartEE75 See my own answer. The IXYS switches were the issue. Changing to the Vishay SSRs solved the problem. \$\endgroup\$ Commented Apr 6, 2021 at 23:40
We went ahead with a test board to verify if the Vishay SSRs (Vishay VOR1142B4) would work for our application. The short answer is yes, they do. These do not show any of the problems of the IXYS CPC7524 which suggests that the problem with those switches is the protection circuitry removing the bias during relatively slow transient conditions.
As can be seen in the following figure, without a load, both sides of the switch are undistinguishable from each other (the two traces are on top of each other), which was not the case with the previous switches.
Simple switch test
The following is a figure that shows a similar test condition as indicated in the question above (only the critical traces shown, as other tests confirm the 400pF parasitic capacitance on the nodes and the traces across the switch are nearly indistinguishable from each other with a quite consistent and constant 22Ω series resistance).
Driving a current through the switches
Note that the voltage at CH1 reaches the feedback condition almost instantaneously on turn-on with no chatter or other issues, however other circuit imperfections mostly due to parasitic capacitances across M1 have now come to light.
This comes to confirm that old adage of "simpler is better."
  • \$\begingroup\$ Good choice I read, the IXYS is 60 pF and the Vishay is 6 pF @ 50V (+1) can’t always have the same conditions as spec. \$\endgroup\$ Commented Apr 7, 2021 at 1:05
