Can someone explain how this part of the circuit works? Why do they use PNP (Q5
), NPN (Q2
, Q3
) transistors with inductor (L1
) and diode (D1
)? The Li-ion charger is a BQ2954.
The description for pin 14, MOD
says:
Current-switching control output
Pulse-width modulated push/pull output used to control the charging current to the battery. MOD switches high to enable current flow and low to inhibit current flow. (The maximum duty cycle is 80%.)
Thank you for help.
