I'm working on a project where I have a 12 V voltage supply. I need reference voltages of 4.5 V and 3 V which will be each be used as the Vref for a comparator. I am aware that I shouldn't use a divider to split these voltages. I wanted to use voltage regulators to do so, but I am not sure exactly how to get 2 reference voltages using regulators. I am very much a beginner, so simple explanations/guidance would be appreciated greatly!
Edit:
First attempt at regulation, resistors not selected correctly
  • \$\begingroup\$ 4.5v and 3v aren't that common, so use an adjustable regulator like the lm317, and dial it to exactly the output voltage you want. \$\endgroup\$
    – dandavis
    Jan 27, 2021 at 3:49
  • \$\begingroup\$ Yes, I plan to use adjustable regulators, but if I need 2 reference voltages, do I need to use 2 regulators? Would these be connected in parallel to the voltage source? \$\endgroup\$
    – acwlgi
    Jan 27, 2021 at 3:52
  • \$\begingroup\$ you could switch a single 317 between 2 voltages by shorting a feedback resistor, but that's going to lower precision. 12 goes into both, gnd goes into both, 4.5v comes out one, 3v out the other. You might want to buy a module that has all the terminals, capacitors and a trim potentiometer in one stable, heatsinked, and easy-to-use piece, they can be had for 1usd... \$\endgroup\$
    – dandavis
    Jan 27, 2021 at 3:55
  • \$\begingroup\$ Hmm, now that i think about it, you actually could use a voltage divider since your comparator draws no current from the inputs. Only downside is that 12v fluctuations will scale down, whereas an LM317 will keep it very stable. \$\endgroup\$
    – dandavis
    Jan 27, 2021 at 3:59
    \$\begingroup\$ LM317 is OK, but it is not designed to be a reference. You may also like to consider this:TL431 / TL432 Precision Programmable Reference - TL431 ti.com/lit/ds/symlink/…. I have been using it for a couple of my ADC related projects and need more precise analog voltage references. So far so good. \$\endgroup\$
    – tlfong01
    Jan 27, 2021 at 4:09
Okay, 0.1V out of 4.5V is +/-2% or so. So a regulator with a 5% tolerance won't be good enough unless you trim it.
Here is one way (Circuitlab is declining to work, so screen cap will have to do)
R1 can be 5%, the others should be at least 1%. The precision resistor values are from the E96 series, so they can be easily purchased.
U1 is drawn as a zener diode, but it actually is a precision trimmed shunt reference IC.
You could replace R1/U1 with a series 5V regulator or reference provided the performance was good enough when you calculate the error budget.
