I would like to use an isolated DC/DC converter SIP to generate 19 V from a 12 V input voltage for a gate drive application with approximately 1.2 W output power required. The isolation voltage should be 5.2 kV.
Looking at the Murata's DCDC catalog there seems to be no obvious solution. Choosing a slightly higher output voltage and using an additional linear regulator would be an option. For example, the MEJ2D1212SC could be used to generate +-12 V to generate 24 V essentially. However, this will cause quite some additional (possibly unnecessary) power dissipation in the linear regulator.
The actual question is regarding the MGJ2D121505SC with output voltages of +15 V and -5 V. Using this as a 20 V supply would be favorable. However, the specified output currents are relatively low compared to the 2 W power specification as can be seen here:
Is the power rating just a general approximation and the output currents are the meaningful data? When using this as a 20 V source, would I be limited to the 40 mA of "Output Current 2"?
