I'm preparing to cut apart a non-trivial $ device and try to extend a 4-conductor cable, so I have been practicing my splicing skills. I figured a USB cable would be a good test.
I spliced, heat-shrink-insulated each solder splice and also soldered the ground wire. I wanted to see if the thing would actually transmit data once I was done, so I tried to get the original foil shield re-wrapped around the splices, but of course they wouldn't quite go.
I figured I could get a connected layer of aluminum around that spot fairly easily if I wrapped the works with some aluminum foil from the kitchen. I had foil on foil on ground wire, squeezed it tight, then heat-shrink wrapped the whole thing. It seems to charge fine right around 5 volts, and plugging my Anrdoid phone into my PC, the data flow seems good too. I ran some file operations on the phone from the PC and copied a few folders of music for a minor test.
I'm curious if that aluminum foil is working as a shield or if shielding not that big a deal in such conditions.
Is an aluminum foil wrap working as a shield in my spliced USB cable?
