We have a small IoT device, that runs of an external 24v DC power supply brick (https://www.rapidonline.com/tt-electronics-t6367st-24vdc-60w-installation-smpsu-85-3795)
This 24v supply connects to the input side of a switch-mode converter (TPS56637) through a power barrel (L722RAS), that converts it to 3.4v used internally in the device. The switch-mode supply is designed by TI's Webench Power Designer (https://webench.ti.com/power-designer/switching-regulator?powerSupply=0). The specific design report is available here: https://www.dropbox.com/s/2uqugyhv0k8v8zb/Power%20supply%20report%20-%203v5.pdf?dl=0
The problem is, that we sometimes experience that plugging in the power connector kills the switch-mode controller. We cannot seem to figure out why this happens, though we suspect high in-rush currents from the output capacitors in the AC-DC brick? What is the appropriate way of solving an issue like this? We can replicate the problem by inserting and removing the power connecter a few times within a short timeframe.
