I'm interested in putting together both a fixed rack, and a modular rack system using gigabit ethernet for the backplane.
I was thinking of this where the fixed backplane would use something like a 14-port switch chip to allow for 12 in rack modules, plus a possible 'upstream' and 'downstream' connection to extend the rack. For the modular rack, where the rack is built by clipping additional modules in, it would use something like a 3-port switch in each module. With 'upstream', 'downstream' and 'module' connections.
It appears that 803.2ap or 1000basekx are the 'standards' for backplane ethernet, however I've been unable to find any switch ICs that would match what I would expect for this. Does anyone know of vendors / chips which support this?
I've seen some chips from Microchip VSC7511 (4-port switch with SimpliPHY), although the pin count for these chips seems a lot higher than I would have expected. e.g. the VS7511 (4 port) has a pin count of 172 (QFN) vs something like the KSZ9896 (6 port) with a pin count of 128 (QFP).
I really would like to avoid having to use magnetics twice on every link however.
I'm open to any other ideas for a nice (modern) multi-master backplane bus system also.
