I'm trying to design a simple BLDC motor controller using L6234 driver IC. Looking at its application reference schematic I came across some weird pull-ups (highlighted in green, I assume these function as pull-up resistors but please correct me if I'm wrong).
What are these pull-ups for? I understand the use of pull-up and pull-down resistors when they are used to prevent say button input from floating. But in this case control logic IC outputs PWM signals to control L6234 IC. If these are here to prevent floating enables and inputs while control logic IC is booting then why are these pull-ups instead of being pull-downs?
I'm rather inexperienced hobbyist, am I missing something more fundamental here?
