I have a 24FC01, 1 kbit EEPROM on my board. The SDA and SCL lines are pulled up to 3.3V through two 2k resistors. I'm using a STM32F407 MCU to read and write data to the EEPROM. Using the HAL libraries, I'm trying to check if the device is ready using HAL_I2C_IsDeviceReady(&i2c2, 0x50, 2, 100)
function. However, this fails and returns false. The I2C is configured in CubeMX
with 100 kHz clock speed and 7-bit addressing. What am I missing?
From the HAL source code:
DevAddress Target device address: The device 7 bits address value in datasheet must be shifted to the left before calling the interface
n.b. shifted to the left by one bit.
