I have a problem on a switch contactor on high power load control. It is expected because the load is up to 200 amperes at 48V DC, resistive load.
How do I protect the contacts from a full load turn off and prevent the arcing on the contacts?
The resistive load is low ohmic resistors that draw 20 amperes each from a high capacitty battery. Yeah, they are big.
The contactor is rated 200 amperes continuous load, the coil is 24V. Kink.
It is a Brazilian part, used for motor start, but can be used continuously.
If it is not possible to upgrade the design what other components are ideal for DC high load switching?
There is "nothing" on the circuit except the resistor, the contactor switch and the battery, switch on low side.
