I want to use the simple camera ov7670 and that camera requires a system clock, called XCLK.
The clock requries 24 MHz input from a source that are at 50% duty call and a period of 24 nanoseconds. enter image description here
Does this mean that I should use a PWM signal from a micro controller, or should I use an external crystal oscillator?
http://web.mit.edu/6.111/www/f2016/tools/OV7670_2006.pdf
    \$\begingroup\$ if you have a microcontroller that can output a 24 MHz clock signal, then go for it \$\endgroup\$
    – jsotola
    Feb 1 '21 at 21:47
  • \$\begingroup\$ @jsotola Yes. I have an STM32 where the PWM's are very very high. Servral MHz. \$\endgroup\$
    – MrYui
    Feb 1 '21 at 21:48
You should use an external Crystal Osc. (XO) with the duty cycle specifications given. That will satisfy the pulse width variations given for the range of frequencies also given.
  • \$\begingroup\$ So using a PWM output, is a bad idea? Even if the input requries a CMOS clock signal e.g square wave. \$\endgroup\$
    – MrYui
    Feb 1 '21 at 23:20
  • \$\begingroup\$ Yes , it's a bad idea. PWM is not used at these frequencies. and the fastest clocks for CMOS need to be symmetrical \$\endgroup\$ Feb 1 '21 at 23:41
  • \$\begingroup\$ Ok. Thank you! Best answer! :) \$\endgroup\$
    – MrYui
    Feb 2 '21 at 0:02
many STM32 microcontrollers have a MCO output. (MCO standing for "Master Clock Out"). it's a general purpose clock output which is derived from a flexible selection of various clock sources and a clock prescaler. here's an image from the STM32F030 datasheet:
STM32 MCO output
The XCLK on 7670 could be from 10MHz to 48MHz. it's not 24MHz necessarily.
  • \$\begingroup\$ Sorry! I using a STM32F407 \$\endgroup\$
    – MrYui
    Feb 1 '21 at 23:20
