Seems like a simple question but I've searched and not found good answers.
It comes down to signal to noise ratio equation. What are the differences between the generations in terms of:
  • Frequencies ranges used
  • Modulation types
  • Signal strength (amount of towers)
  • Spectrum re-use (smart antenna/comm systems)
I can't think of anything else that makes a fundamental difference to the data rate, so it must be mainly these parameters that change between 3G,4G, 5G and 6G...
Please help
  • \$\begingroup\$ Have you tried searching for the specifications of each standard? \$\endgroup\$
    – K H
    Feb 2, 2021 at 5:45
  • \$\begingroup\$ Best asked here: dsp.stackexchange.com \$\endgroup\$
    – P2000
    Feb 2, 2021 at 5:55
    \$\begingroup\$ Hi Natalie, your suspicion is right: this is really not much of a simple question! You're basically asking about "what happened in ca 23 years of rapid technological advancement"; your four things are right, and they are important, but it's much more than that! \$\endgroup\$ Feb 2, 2021 at 7:41
This is really not much of a simple question. You're basically asking about "what happened in ca 23 years of rapid technological advancement"; your four things are right, and they are important, but it's much more than that!
That is, if you had perfect channel knowledge (to make your channel perfectly flat), and perfect channel coding (to make use of that SNR).
Neither is the case!
Differences … Frequencies ranges used
Not really any. OK; 5G New Radio opened up the millimeter waves. Other than that, not much happened: Differing allocations in different countries ranging from ca 800 MHz to ca 3.4 GHz. The availability of these really has less to do with the standards than with local laws. It's a regulation thing, not a standardization thing!
Communication bandwidths of course changed, but at the same time, more modern standards tend to be able to divide the spectrum in a more finely-grained manner, so this is hard to put into a few words. Basically: Read the 4G physical layer standards, that shows how diverse things are.
Differences … Modulation types
oh. Like, basically, everything. 3G used to be a CDMA system in most cases (you'll notice that I use "most" here: it's by far not as uniform as people think). That comes with its own challenges to equalization, channel sensing, and power control. This leads to different choices in modulations contained in the chips than what you'd choose in an OFDM/TDD or OFDMA system like 4G and later.
Differences … Signal strength (amount of towers)
That makes no sense. The standards don't define how many towers you build. It's the regulations that define how much power a tower can transmit, or a handheld. And it's mainly economic reasons why you put up more or fewer towers. The keyword you'd want to research here is network densification.
Differences … Spectrum re-use (smart antenna/comm systems)
Well, again, you have to consider the differences in multi-user access: CDMA vs OFDM/TDD or OFMDA.
Then, 4G saw the introduction of MIMO techniques (which are much easier to build with OFDM).
That goes well with smaller segmentation. ("smart comms systems": um, I guess everything is kind of smart?)
Nope! These are really important, but would play a minor role without changes elsewhere in the system. Because I can't write a book series on 3G/4G/5G, just a few things to give you ideas about things that gotten better, which have a significant influence on throughput:
  • Channel Codes (!!)
  • Equalizers / OFDM equalization
  • Time-Variant channel estimation / prediction
  • Diversity techniques / MIMO
  • Amplifier linearity
  • Self-interference cancellation
  • Reduced signalling overhead
  • Interleavers
  • Checksumming
  • Retransmission Protocols / ARQ
  • Local Buffering at Base Stations and larger user equipment memories
  • Latency of control & ACK / Allowing for contention windows to work with that
  • Resource Reallocation
  • Network Planning tools
  • Immensely reduced power demand of silicon hardware leading to availability of way more advanced versions of all the above on both user equipment and base station site
  • Immensely reduced upfront cost for basestation deployment, meaning that cells with fewer users make sense economically now, which wouldn't have been feasible before
This list is far from complete, and you really mustn't assume some of these points play a minor role in your youtube streaming speed just because they seem to be higher up the stack than others or even of a financial, non-technical nature.
The major technological changes are
  • 1G: analog systems
  • 2G: first digital system, uses time and frequency to separate stations, but baseband can be implemented in hardware
  • 2.5G: allows stations to change modulation inside a packet, allowing more efficient modulation for data (which is only interesting for the receiver) than for control signals (that still need to conform to GSM spec because all stations need it to coordinate)
  • 3G: introduces code domain multiplexing, which scales better to many stations than 2G, but requires lots of processing on base stations
  • 4G: decouples channel allocation from transmission standards, allowing stations to negotiate more efficient modulation standards -- but mobile stations need more baseband processing
  • 5G: allows networks to negotiate alternate transport mechanisms on different frequency bands
Each step extends digital baseband processing, so these are dependent on power-efficient DSP ICs, i.e. smaller process nodes in semiconductor fabrication.
