Distributed element filters are called that to distinguish them from lumped element filters.
In a lumped element filter, assuming it was practically possible to have zero-size components, then in theory you could build the filter in zero size, electrical length is not required for it to function.
In a distributed element filter, some, or often all, of the reactive components use their electrical length as an important parameter.
Often, series elements of a low pass filter will be 'thin' lines, having higher impedance than the system impedance, so looking inductive. In a hand-waving way you can understand how they might work as inductors. However, to understand accurately the effect they have on the response of the filter, you need to factor in their electrical length. A special electrical length is λ/4, this transforms a short at one end to an open at the other.
A common low pass filter construction is a through transmission line with a number of 'capacitive' shunt elements to ground at λ/4 spacings. For accuracy, these are often built as 'bow-ties', so their connection point to the line can be accurately defined. The length of these bow-ties is more of an important parameter than their total (capacitive) area. Although this filter looks like a cascade of inductor/capacitor sections to the casual eye, it still works with a system-impedance through line, and relies on the impedance transformation of each quarter wavelength section.
