Initially I trawled posts and forums (initially to debug some noise, squeals, and oscillations on some LM386 circuits I built). I've synthesised all of that knowledge and re-approached this IC, calculating a load of component values.
I get that there are lots of posts/questions about LM386. I'm asking if I've stitched all of the answers together properly and therefore wanted to run this past some people more knowledgable than myself. I've not breadboarded this yet as I don't have all the components and was looking for some feedback before I order.
Also, please note that I am a complete amateur here. I’m more than capable of plugging numbers into calculations but I don’t fully understand all of the concepts behind these. I’d never heard of Xc for example.
Here's the datasheet for anyone who needs it - https://www.ti.com/lit/ds/symlink/lm386.pdf
Here's a schematic: LM386 Schematic
So, first of all, C1, the input DC blocking capacitor. The 10K volume pot in parallel with the IC's 50K input impedance results in 8.3K input resistance.
I'm aiming for Xc lower than 8.3K/10 at 100hz (this is low enough for my application, 20hz seems excessive for me). A 2.2µF cap gives Xc of 0.72KΩ at 100Hz so this seems good to me. This is higher than any other LM386 amplifier design I’ve seen online though (ranging from 47nF to 1µF)?
Next, C2. I went by the datasheet which shows 50µF as the best frequency response (Fig 2. Power Supply Rejection vs Frequency). The graph is for 6V supply though and I’m using 9V so I’m unsure what impact that might have. Again, 50µF is higher than the e.g. 0.1µF I’ve seen elsewhere.
For C3, I’m connecting to a miniature 8Ω speaker (well actually vibration speaker element so a speaker coil driver without the cone). The chip’s output resistance is 0.1Ω so I have a total output resistance of 8.1Ω. To work out the capacitor I’m aiming for Xc less than 8.1Ω/10 at 100Hz. A 2,200µF cap gives me 0.72Ω at 100Hz. This is much higher than used in many other circuit. Size and cost seems a more likely factor behind this and I have seen 2,200µF recommended elsewhere.
C4 and R1 form part of the Zobel network. Rather than take the standard values seen in many circuits (generally 10R and 47nF) I calculated these. My speaker has a voce coil/DC resistance of 7.4Ω. recommended resistor value is this times 1.25 and so 9.25Ω. 10Ω resistor is fine. For the cap the calculation is Le (voice coil inductance) / R (9.25Ω above) * R (well R squared but I can’t do superscript 2). Le for my speaker driver is 0.06mH. I dived this by 1000 to get Henries (and multiplied the result of the calculation by 1000000 to get µF) resulting in 0.61µF. I understand that going higher should be fine so a 1µF cap is an easy value.
C5 and C6 are power supply filtering/decoupling. I couldn’t find a source to calculate this so went with a range of advice and settled on 100µF and 0.1µF.
I’m leaving pins 1 and 8 open as 20 gain should be enough for me.
I’m using the inverting input (pin 2) as it’s suggested that it sounds better.
As my calculations result in some higher value capacitors than I’ve generally seen I’ve plumped for some polarised elctrolytics where I don’t usually see them (C1 and C2) so I’m unsure about polarity here.
Phew, so that’s the schematic. I’ve also laid out a board design based upon all of this and taking into account best practice I’ve seen. There’s especially an issue with keeping in, out, and power grounding separated and so I’ve done my best here at star grounding on pin 4 (any good?). I’m using non-standard symbols (heavily drawn from Peter Blasser’s paper circuits) but the one’s which should be hardest to figure out are the circles with black triangles next to them. These are for the input and output jack grounds. Oh, and the weird 'power obelisk' to the right is where the 9V battery supply will connect.
LM386 PCB layout
I appreciate that there’ll be a range of factors such as space and cost and so I’m just aiming for something more ‘ideal’ than practical at this stage.
So, anyone who actually understands all of this properly able to comment?
Thanks for your time.(
  • \$\begingroup\$ It's hard for me to reconcile "artistically placed components with no current return paths underneath" with "best practices"; let's face it, even if this is low frequency by any means, best-practice circuit boards look rather regular and boring. (This matters a bit, but not too much: the LM386, even in a perfect layout, is a really really crappy amplifier, and you'd better be investing your time and external components (which are more expensive than the amplifier here, quickly) in something that isn't per se terrible) \$\endgroup\$ Feb 2, 2021 at 10:51
  • \$\begingroup\$ Why is there an issue keeping the grounds separated? I don't see why doing that would be desirable at all? \$\endgroup\$ Feb 2, 2021 at 10:53
    \$\begingroup\$ Looks to me like you're doing this a bit too much "from scratch" and that leaves you with lots and lots of uncertainties, doubts and overthinking. My suggestion: look at what others do. Study some projects that also use the LM386. Order a module which uses the LM386 (these modules are very cheap and just work). There are many small details you don't know about (yet) and taking that all into account at your skill level is impossible. So just copy what other do. With more experience you'll understand why things are done like that. \$\endgroup\$ Feb 2, 2021 at 11:13
  • \$\begingroup\$ @MarcusMüllerfiar point about the 'artistic' pcb layout. At the moment 'current return paths' are beyond me. \$\endgroup\$ Feb 2, 2021 at 14:47
  • \$\begingroup\$ @MarcusMüllerre: grounding. e.g. youtube.com/watch?v=lBGE5lwbruE (there are others but I can't find them right now) \$\endgroup\$ Feb 2, 2021 at 14:48
First problem is that usually a PP3/LR61 type 9V battery can't provide enough current to power the amplifier to drive an 8 ohm speaker.
Otherwise the component values are pretty sane, except for the Zobel capacitor. 1 uF with 10 ohms Zobel network is an RC filter with 3dB point at 16kHz, which is well within audio band. It means that at that frequency you have both the speaker and the Zobel network loading the output, so extra power is needed. The original Zobel network is made to stabilize the output by having the 3dB point at near 300kHz which is the bandwidth of the chip.
The 2200uF output cap is kind of overkill, but with a 8 ohm speaker it does provide 3dB point at 9HZ, which means the phase will be linear down to 90Hz or so.
Just don't expect Hi-Fi quality out of it, especially when powered with a 9V battery.
  • \$\begingroup\$ They used to sell little speaker boxes with an LM386, a small 8 ohm speaker, and a 9V battery inside. They'd run for hours, no problem. The battery isn't the limit on the sound quality of the LM386, it is the LM386 itself. \$\endgroup\$
    – JRE
    Feb 2, 2021 at 12:24
  • \$\begingroup\$ @justme Thanks, that's interesting about the zobel network. I used one of a handful of pages I could find about calculating the zobel networks e.g. audiojudgement.com/impedance-equalization-circuit-zobel-network You've appear to have approached it as an RC lowpass filter? Do you know anything about the difference in approach and pros\cons. \$\endgroup\$ Feb 2, 2021 at 15:02
  • \$\begingroup\$ The point is not to make the chip have a constant impedance load based on your specific speaker, but to just have enough high frequency load so it is stable. We don't know why and how the datasheet ended up with these values, but they would not suggest these values if they were poor values. \$\endgroup\$
    – Justme
    Feb 2, 2021 at 15:20
  • \$\begingroup\$ @Justme cool, thanks. \$\endgroup\$ Feb 2, 2021 at 20:31
