I don't know much about motors, but I have one in mind for my purpose. You can see an image of it, and I'd like to know how to wire the terminal plate. I plan to use a belt from the motor shaft to turn a shaft on a spherical container for several days. Can anyone tell me if this is a continuous duty motor? I'd be grateful for anyone's help.
Specs: Synchronous Motor 60KTYZ 110V AC 60Hz 80 RPM CW/CCW 14W Gear Motor
Rated voltage: 110V AC
Rated frequency: 50 ~ 60HZ
Product model: 60KTYZ
Product size: 60mm*60mm
Input power: 14W
Output power: 3.4W
Input current: 63mA
Outlet shaft diameter: 7mm
Shaft length: 18mm
Out shaft position: middle and out shaft
Rotation direction: positive and negative bidirectional (CW/CCW)
Application environment: Temp (-15 -40 OC) Humidity = 90%
Noise: less than or equal to 35dB
Insulation class: E class
Security authentication: CCC, CE, RoHS.
Speed: 80 RPM
  • \$\begingroup\$ What torque is needed? Direction? No instructions? Use centre and either outside screw to change direction \$\endgroup\$ Feb 2, 2021 at 19:01
  • \$\begingroup\$ If rust has weakened the steel artwork already, an abrasion drum to clean may weaken it more. Consider other methods to refinish it.bobvila.com/articles/best-rust-remover \$\endgroup\$ Feb 2, 2021 at 19:41
    \$\begingroup\$ That motor seems to be very similar to the one in this question: electronics.stackexchange.com/questions/545999/… The connection is likely the same. \$\endgroup\$
    – user80875
    Feb 2, 2021 at 21:11
  • \$\begingroup\$ I'm not knowledgeable about torque. Does it relate to the weight of the part being pulled by the drive belt? The spherical part the belt drive will hopefully rotate weighs about 8 pounds. I shopped on eBay and asked the seller if he could advise me about wiring, or if the motor came with wiring instructions. but I got no reply. I also searched online for pre-wired 60 - 80 rpm motors, but the results weren't useful. I know when dealing with an electrical device there's no room for error. Error could = fatality. \$\endgroup\$
    – DawnaR
    Feb 4, 2021 at 3:59
4 Answers 4
I can’t say for certain but I’d be highly confident that this is continuously rated. Firstly, synchronous motors aren’t well suited to stop-start operations, and if it weren’t continuously rated then I would expect the rated on/off times to be published prominently alongside the power/torque.
I can’t say how to wire it, but I’d expect that there are two windings, one direct across live-neutral and one with that red capacitor in series to provide a phase shift.
From the specs it seems a timer motor… in short a motor designed to turn clock gears (for periodic controls and such things). Definitely continuous duty and more importantly precise speed (that's the advantage of small sync motors). In europe the 50Hz version is often 60 RPM on the spindle so they are almost clocks in themselves.
However it's quite a small motor (the gear train usually only has cam switches and such), with only 14W I don't know if it fits your application.
For wiring use the middle and one of the end terminals depending on which direction you want it to spin.
as others have said it's suited for continuous operation
Here's the schematic.
Power is applied to the red and black leads for one direction of rotation and blue and black for the other.
It's a continuous duty motor.
  • \$\begingroup\$ Thank you very much for your help. I only need the motor to rotate in one direction, so this is good to know. Thanks for telling me this is a continuous duty motor. I hope this is an appropriate comment. \$\endgroup\$
    – DawnaR
    Feb 4, 2021 at 3:49
  • \$\begingroup\$ Anytime, DawnaR! I do hope you find that the motor suits your application. All okay. \$\endgroup\$
    – vu2nan
    Feb 4, 2021 at 7:08
